I last did some firmware updating back in May and I think things were working OK then, but now I find that Chrysalis often does not connect to my M100 unless I unplug and replug it. I suspect this might also happen if I’ve left the Arduino IDE open, or perhaps even used it since the last time Chrysalis ran. I do sometimes use the Serial Monitor in the IDE, but it’s usually switched off.
I updated the udev rules earlier in the year and the keyboard appears in the list of paired devices, but the first attempt to connect will just drop to the Chrysalis front page. If I keep trying I’ll eventually get to the udev rules warning, but the keyboard won’t connect until I reset it.
It seems like I now can’t actually update firmware using Chrysalis without doing an unplug/replug rather than just holding the Prog key (in addition to the reset I might’ve already done when starting Chrysalis). Updating directly from the IDE stopped working a long time ago.
All this unplugging can’t be doing the cable and the USB port any good, so I took a diversion through the idea of software reset, but Arduino complains about not finding headers (that are clearly there) and since I don’t really know what I’m doing I can’t evaluate whether that code is still relevant.
Weird solution/workaround: After some more experimentation I’ve found that after running the IDE with Serial Monitor active, Chrysalis will connect to the keyboard, but if I exit and try again it will not until I’ve run the IDE again.
It’s useful to have Chrysalis open when working on something in Kaleidoscope just for a visual reminder of how things are setup. The keymaps in the sketch are just too abstract, no matter how carefully I space them.
All in all, it’s disappointing that this has become so haphazard.
