Would like the Model 100 to send F22 from one palm key to activate an Autohotkey macro. Have tried custom keycodes 85 (hex VK code for F22) and 133 (decimal). What’s the trick, please?
Many thanks!
Many thanks!
The custom codes to use are the USB HID codes, for F13-F24, that’s 104-115. Chrysalis should correctly display those as Fx keys once assigned, we just don’t have them on the floating key picker at the moment.
Excellent, that works. Thank you very much!
