Hi,
How do I set the pattern or color when switching layer?
One of the layers already does that, but I do not seem to see where there is set up.
Kind regards
Hi,
Kind regards
depends… if you are creating your firmware yourself, you could have a look at mine - I created a plugin that actually does that. It switches the LED Color Effekt when switching layers: GitHub - sboesebeck/keyboardioLayout: my layout for the model01
With chrysalis alone this is not possible…
Thank you for the response.
I am trying to figure out, what is going on, as I hold down the layer 1 switch key, a certain pattern is shown from the LEDs.
This does not happen for my layer 2 switch key.
There is a special plugin for the NUM pad layer to highlight which keys are the NUM pad. It’s not customisable as far as I’m aware.
Thank you for the clarification ![]()
