Dead key on Madel 01
Hi everyone,
After a switch failed on my Model 01, I changed it with a bit of soldering. After many tries, I concluded it was a PCB isssue.
The switch on its own works fine (I tested it) and tried with a primitive switch. It’s still not working.
I don’t have the energy and the knowledge for finding the issue on my own, is there a way to get repair from anyone from Keyboardio, or do you recommand getting in contact with a local repair shop? I’m located in France.
Thanks,
Alyx
What a pity!
Seeing the low activity on the forums and sparse replies from Keyboardio, I’d bet on local repair.
I recall someone in France has amassed a fairly large amount of keyboards, maybe they can help you out (either by swapping, repairing or advice). I’ll append the user name if I recall it. → I was thinking of @alex.centar
Youre correct ! I have a lot of Spare switches. I can help.
Thanks for the reply, but I may have found a bodgy workaround that involves sacrifying another key… I may post my work when it’s done.
Told you it was dirty.
Now the S key activates the escape key. Changed the layout so escape prints S instead. Escape key was already maped on another key.
