Double-left hand keyboard?
Just out of silly curiosity, what happens if someone with two Model01’s connects two left-half keyboards together with an RJ45 cable? With just one of them plugged in via USB? With both plugged in?
Likewise, what happens when both halves, instead of being plugged into each other, are instead plugged into an old 10Base-T router?
(Note: not switch, as that would be guaranteed to not work; we’re looking for something that blindly rebroadcasts input to all other connections.)
And if that works, what happens when multiple halves are plugged into the same router?
:thinking:
I’ll make this easy: Don’t do that.
Among other things, the hardware is not designed to be plugged into an ethernet hub or router.
It’s also not designed to be plugged into itself.
someone’s guaranteed to do it now! :smiley:
Indeed. And it will be something along the lines of: “Hey this connector looks like it will fit in this other thing. What happens when I link them together… Whoops!”
That is, unfortunately, the danger of using a commodity connector.
At some point, I ought to test these scenarios again, up to and including seeing what happens if you plug in a Power Over Ethernet cable.
Nobody else should try this. Seriously.
I’m feeling a bit guilty for posting this in the first place. I certainly hope nobody tries it.
Nah. It’s much better to talk about it in public.
And it’s a legit question. And a legit issue with designing with commodity connectors.
