I know it is counterproductive to say it does not work, but it is the only way I can describe this problem. I picked up the keyboard today after some time of not using it and plugged it in to my laptop and… It does not work, nothing happens. I try to type something (obviously not using it now), and nothing happens. I change USB port, checking connectors, but still the same. In the past I had some problems with the RJ5 connectors between the keyboard parts, but even so, it should work? Then I downloaded Arduino, setting it up, only to find “Ports” are grayed out. So I cannot flash any firmware to the Keyboard (?). I am on Windows 10, if that matters.
So yeah, I have done everything I can think of. The USB cable works, I can connect my phone, and USB ports on the computer works. The keyboard worked a few months ago but after time of not using it, I cannot get it work again.
Ideas? How can I proceed?
