Well, I certainly admire the level of overkill.
I have the Wristocats coming in and am waiting on my Keyboardio in MP5. Iāll comment here on if they work out in combination or not!
oh dang, Iād be really interested in knowing how that works out. Being an Indiegogo project I assumed it was just pie-in-the-sky vaporware but it looks like theyāre actually shipping now? Neat!
I got the Wristocats in, they are heavenly! Seriously, everyone that touches them is amazed at how soft and supportive they are!
Problem is I donāt know if they will work well with the Keyboardio due to their height. However, they may work without the base. The great thing is they came with 3 different pads and I think, if anything, one of those pads will work really well on the Keyvoardio without the base and then you still have the Wristocats for other things which is why I felt fine ordering them.
@TreTuna I would be interested in hearing your opinion about the Wristocats too.
My main concerns are:
- do they fit on the wrist area of the Model 01? They look too big for it.
- with the way they elevate your wrists, can you still comfortably press the FN key?
- resting my wrist on the keyboardās wooden wrist area is pretty uncomfortable if Iām wearing a wristwatch. Do the Wristocats help in this regard?
Iāll let you know as soon as my mp5 01 comes in!
My arts-and-crafts palm rests ended up not really helping in the long run and Iām still looking for something better. Maybe Iāll try just putting a loop of painterās tape on the bottom of the gel rests I was using before, since those were comfortable, at least.
Well, this is the first post Iām typing on the Keyboardio here and sadly itās to report that the Wristocats are definitely not the way to go here. They are just too big for it. I definitely want to find something of the same comfort level, but these are not them.
I even tried the lowest profile pad without the main base and it almost worked out, but I couldnāt get to the palm keys well enough.
The thick gel wrests are pissing me off again. Maybe I just need to learn to not wrest my hands on the keyboard while I type.
This looks very interesting. Do you have a pic from the front?
Iām assuming the rice filled wrest is higher than the keyboard itselfā¦
Ergonomically, should this not be high at the front and centre back - then tented down in the back left and right corners?
The perimeter profile of the rest is somewhat fixed, but since it is filled with rice the levels at which your hands or arms sit can be adjusted by gathering or distributing the rice as needed.
If weāre really going to get into it, wrist rests tend to be used incorrectlyāthey are wrist rests, not stands. Ideally, you should float your hands over the keys and only rest them when needed, for short periods. And if you really want to get into it, your keyboard should be tented so much it should be (almost) vertical, which pretty much precludes the use of wrist rests in the first place!
