My right control key seems to be double registering. I have one-shot modifiers enabled on it and every time it’s tapped it locks as if it’s been tapped twice. All other one-shot modifiers are fine. The double tap seems to occur around 80% of the time. I think this is a problem with the switch rather than the plugin, although I probably wouldn’t have noticed without it.
Should I try and take the switch apart and clean it, if so, are there any instructions?
