Hello,
I really like the Atreus, but I am having much trouble configuring the layout, particularly adding symbol keys such as ^, ?, _, ~, <, >, |, etc.
Within Chrysalis, under Layout Editor, a complete keyboard is present under the Atreus interactive keyboard, but I can only click and add keys that do not require the shift key being held.
When I hover the mouse over each key, the other symbols show in a small hover box, but it seems there isn’t a way to add them to the Atreus keymap.
Is there any way to add the keys that require holding shift?
Within Chrysalis, I also see there is a ‘Kaleidoscope Custom Key Code’ box under ‘Advanced’; is there a list of the codes and their characters somewhere?
I have tried searching the internet for such a list but have not found one; am I missing something?
I made a text file list of the codes that were already added and moving keys by entering these codes in that key code box seems to work but I need to add characters that aren’t already present and don’t have the codes.
Thank you for any assistance; I’ve put a lot of time into this and can’t seem to get it.
I don’t know enough to move away from the graphical editor Chrysalis, but would really like to add these symbols so I can use the complete keyboard.
Thanks again,
Chris
