Load bépo layout in model 100
Hi !
I would like to load a bépo layout in a model 100 in linux.
There is 2 questions :
1- Chrysalis doesn’t load the layout I use on linux (BÉPO), but AZERTY. Still, when I type, the layout is BÉPO. There is an inconsistency between the layout Chrysalis display and the one I use. How can I configure Chysalis to make it display the good layout ?
2- Is there an available bépo layout for the model 100 ?
Thanks for your help
Sepio
Hi,
Sorry for necroing this post but I just mostly finished my layout :
(clic visu to see the layout, mostly simple bépo with a few ajustement, most notably a few peripherical keys are moved, the num pad is linéar on layer #2. Navigation, Fkeys and mouse on #1)
visuLayout
change the extension to json to import in krysalis
Chrysalis_Keyboardio-Model-100_layout_2025-07-09_22-22-05.txt (79.3 KB)
