The A key on my model 01 sometimes does not register key presses and sometimes it registers more presses than what I’ve done (e.g. I could press it and it might insert two or three As). Last time this happened I cleaned it very mildly and it went away. I’m probably going to soon do a deeper clean.
Any advice on how to fix this or things to try? Maybe cleaning methods that might help? Thanks
This has happened to me and cleaning did not fix it. I ended up buying a solder and learning to replace faulty keys myself. I’m a heavy typer working as a programmer and I’ve switched out 3 keys on my Model 01 so far.
